Tune Ups
raybo3
Administrator Posts: 5,592 admin
How often do you Tune up your boat?
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Best Answers
skennelly
Member Posts: 2,196 ✭✭✭✭
Just tuned up this spring...didn't know when PO did it. Glad I did plugs needed it.. My previous boat I did plugs wires and cap every other year...checked them yearly.2002 - 270FV Mag 350 B3 -
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Cap/rotor every 2 years. Plugs last a long time on mine. New plug wires 2 times in 14 years.Past owner of a 2003 342FV
PC BYC, Holland, MI -
JoeStang Member Posts: 1,137 ✭✭✭✭
Probably do cap, rotor, plugs on mine this year. Running perfect at 235 hours and 4 years old, but I'd rather be preventative. Cheap insurance too, and can save hidden money if it's not 100% and using additional fuel.2013 276 Cuddy ~ 350 MAG / B3 -
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
Looks to me like doing a cap and rotor is a simple diy. Right?07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
aero3113
Member Posts: 9,684 ✭✭✭✭✭
Yes, but make sure you only move one wire at a time to the new cap from the old one. You don't want to mess up your firing order!Liberty44140 said:Looks to me like doing a cap and rotor is a simple diy. Right?2008 330EC -
randy56
Member Posts: 4,085 ✭✭✭✭✭
as needed, no time line, plug's last a long time these days.Boat Name :
summer pm:
check fluids
follow gage readings
keep it clean and always run on ethanol free fuel.
add additives to boost octane and clean fuel system from time to time.
Fix things as they come and you will be ahead of the curve.
i end my summer by changing motor oil and oil filters. Makes it easier to warm them up and pump oil out vs spring when it's cold.
Fall:
its time to properly winterize the boat and get her ready for the lay up
engines
water system
ac
drives
all electrical devices
since my oil is fresh I just drain my engines and then flush them with antifreeze
drives stay full of gear lube but I do pop the drain screw to check for water intrusion.
if that's the case then they would be drained.
spring pm:
all systems are commissioned
fuel filters changed
gear lube changed
and all upgrades and upkeep is done.
tune ups:
so cap and rotor I check every year for corrosion and buildup
if I find something I will simply clean contacts and it's good to go. Good time to check pick up sensor for same condition.
check timing at the same time when on the hose.
check belts ans belt tension.
spark plugs should be done every 3rd season on carb boats and 2 seasons on fuels. My buddy has twin 496 fuels and his plugs go to crap every 2 seasons.
spark plug wires is another item that should go years before need of replacement. Take the wire and bend it. Does it separate or do you see dry rot or cracks? Usually good 5 years.
cap and rotor 3 years.
this is all based on run time and how hard the boat is ran.
drive gear lube should be serviced every season and greased.
bellows and boots 3-5 years depending on the condition of the water and use.
water pump every 2 years with alignment and drive being pressure tested.
people that are replace or tune every year are over doing it.
Also put damp rid inside the cabin and defrost the fridge and leave it open.
waste tank can be pumped out and the. 2 gal of pink put in same for the manual
or electrical head.
At winter lay up you have just changed the oil, why would you squirt a can of crap in your ready to go engine. just sayin...... never had an issue.
Rotor and cap are a different story, IMO every 200 hours or 2 years they should be changed. As they have some wear at that point.
Plugs, 10 years, most cars run 100,000 + miles. a boat equivalent 10 years.
Wires, a boat engine does not put off as much heat as a car, but as cheap as they are 200 hours or 2 years with the rotor and cap.
So I think you are right on with your thinking,
RAIN! uggg, this is the second 3 day weekend of spring rain.
I don't fog but stable my tanks and run with it on my way to haul out.
And for you guys who say to use only non-ethanol gas: I envy you. Here in Virginia, the full-on switch to E10 is a distant memory. We're just trying to fight off the move to E15.
LeRea, the marina is the only place I can find non-ethanol, it's not on land anywhere, They order it just for boats, saying it cost a few cents more per gallon, All the boaters requested it, and they got it for us. Perhaps you could do the same.
