Wash down pressure
i have great water pressure everywhere on my 2002 Rinker 342 except my rear wash down. Is this common or does anyone have a trick to get a little more pressure out of it?
    Pressure should be the same, your shower head thing must be clogged. Mine has adjustment for shower or squirt.
    Are you talking about the transom shower or a separate washdown that you actually turn on a Washdown switch?
  • brandonmayberrybrandonmayberry Member Posts: 226 ✭✭
    The transom shower.
    Mine was almost non-operating until I pulled the head off and gave it a good soaking in CLR. Works great now.
    Unscrew the handle from the hose and see what you got. It probably needs cleaned out.
    Makes sense. I'll give it a look over and cleaning and will see what happens. Thanks!
