Where does coax run?
Need to replace the coax TV cable, cannot determine how its run to fish a new one. Anyone found a good path to run one from Port side where shore power is to the th compartment?
    Why not use the old one as a snake?
  • buggyjdavbuggyjdav Posts: 134 ✭✭
    The old one could not be pulled, probably wire tied.
    Thought I would post how I did it for others. The cable comes in and can be accessed from the port under seat compartment, I fed it over into engine compartment, along firewall to Starboard side. Up starboard side from inside engine compartment up past subwoofer. There is an opening in the aft bed area, it's the first shelf on starboard side when entering the aft bed area, then drilled a small hole into closet and ran along the shelf above settee into TV compartment. Done
