Has anyone been having blown fuse issues with the circuit for the automatic bilge pump?
clbkabclbkab Member Posts: 15 ✭✭
I can turn the pump on manually at the helm, but the float switch has blown 2 fuses in under 40 hours of operation on my 2013 Captiva 246
Best Answers
  • VicVic Member Posts: 2
    Answer ✓
    I have the same exact year model boat and encountered the same issue! Rinker is installing 2amp fuses and should be a 5amp. After doing this I have had no issues.
    Then check the float..these do go bad.
    I'm not trying to sound like a total jerk, but fuses pop for a reason.. maybe that reason is they are underequipped to handle a load, but more likely its a bad switch thats jumping to ground.. lift the float by hand on a good fuse and see if you see any spark, or better still, look for evidence of grounding.. there will be burn marks near the switch..
    The bilge pump fuse should be a 3 amp. Check the bilge pump to be sure it has no debris around it or in the base.
