@zaverin1 where exactly are the valves at in relation to the senders? I did my sender last spring when I converted to smartcraft and I didn't see anything
Now why you want it replaced fuel draining back? Grab the 90 deg fitting which is the pickup tube with one wrench then slowly unscrew the valve with other unscrew it and then suck in and then blow out should only work one way when you suck in put your tongue and see if it holds suction
In my other thread I noted the gas dock fill up after replacing two sending units last fall. according to my oem Gages i was within 5 plus or minus gal which is good in my book
when i replaced sending units I also had to remove check valves for clearance. carb models rely on them to keep fuel in the line for easier prime even with electric fuel pumps. reason for sending unit replacement was fuel gages bouncing on plane and port reading only to half tank and dropping to e after On top of that old owner had tank wires reversed at gage cluster so port was star and star was port lol
i assume he is referring to the check valve at the fuel tank pickup tube
this valve screws in
fuel draining back?
good in my book
