Locations for fire extinguisher
WillhoundWillhound Member Posts: 4,242 ✭✭✭✭✭
Curious as to preferred locations for fire extinguishers? On my FV270 I'm thinking one down in the cabin, likely by the door. And a second one on deck near my captains chair.
Maybe up to the right in the footwell where I can reach down and grab it?
    good choice.
    Smart!  Ability to get to the extinguisher fast/easy is key.
    I keep pondering this fire ex (no mess!).
    http://www.fireboy-xintex.com/portable-clean-agent-fire-extinguishers/
    Yikes! Almost $500 for a 5 LB extinguisher. USD.
    IF I ever have to use one, hopefully never, the mess is going to be the least of my concerns....
    Fire boy systems are great for engine compartments
    twins will
    usually have two tanks moUnted
    Mine's a single, but I get the concept. Hand extinguishers going to have to fit the budget for now.
    The dry chemical ones are nothing short of a disaster to clean up afterwards.  Just sayin.  lol
    Reminder
    if you have fireboy system you need to certify tanks every 3 years
    any fire protection company can do that
    only then do they actually qualify towards coast guard count
    Rules in Canada call for a hand extinguisher appropriate to size of boat regardless of on board engine compartment system.  Not all fires are engine related.
    I understand
    30 ft in USA requires 2 extinguishers
    if fire boy system is present then it counts towards the requirement
    so if you had one then you only need one hand held
    if you have two then you still need to carry one for above engine emergencies
    i don't have fire boy system so I carry two
    I think probably about the same here.
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    In our FV310 we have one on the shelf next to the aft berth. The other in the cockpit stbd side near the sink. Easy grab when sitting back there or even from the dock.
    well, as someone that had a fire on the boat, the automatic ones in the engine room are amazing.  And even better, it did not leave any residue at all.
    You are doing right by having them right where you can grab them immediately.
    My first upgrade when I bought my boat was installing a fireboy in the engine compartment.  Peace of mind.
    Patrick
    06 Rinker 270
