carbs
rasburyrasbury Member Posts: 8,823 ✭✭✭✭✭
Well, since you are my go to group, I have a carb that sat with ethanol fuel in it for a couple of years...engine will run but not rev. Carb is from around the 91 time period. I pulled the float bowl and the main jet and it seem to have some crud in it which I cleaned out,reassembled - engine fires right up but bogs when you try to accelerate it...anything obvious I can do to clean the cobwebs out? Ran great before I purchased a boat! I'm driving almost a hundred miles a day and my truck gets about 12 mpg and need this other carb to work. I guess just a rebuild kit and start from scratch?
