Best way to cut fibreglass?
BellevilleMXZ
Member Posts: 732 ✭✭✭
I need to trim a bit , as I bought a door to go where the crappy cooler opening was. I need to trim the edges a bit, whats the best way to do this?
how much is a little bit? a sanding drum on a drill may work best
the door the i got from great lakes skipper matches great color wise and i only had to trim the top corners of the existing opening to get it to fit.
i used masking tape to put over the fiberglass to prevent splintering when you cut. i also used a fine scrolling blade with my jigsaw. the more teeth on the blade the better. put enough tape over the area so the the foot plate of your jigsaw doesn't scratch the gel coat. make your pencil marks on the tape and cut.
here is a link to a thread where i posted a picture of mine completed.
http://rinkerboats.vanillaforums.com/discussion/1875/hatch-doors-in-290ec-etc-where-to-find#latest
need to make two 7 1/2 inch holes for 8 inch pioneer speakers that are coming
ended up using a jig saw with fine tooth blade
