Fridgerator troubles- Solved
anyone a guru here?  Here is what I am coming up with:
On 110vac:
25.66v going into control module
12.4v into transformer
No code flashing on 110 yet unit does not operate.  Fan does come on
12v
1 flash on led, indicates low voltage according to manual I seen
12.2 into transformer
12.45 into control module
Post edited by Wildboating on
    Faulty module. Duhhhhhh. Lol
    Is it really?  Is this the transformer or the controller strip with all the connectors.
    What is going in to compressor?
    The refrigerator should operate at 10V DC
    Thanks.  Hoping the cockpit fridge has same controller on it.   I'm going to swap them and see if it fires up.
  • rasburyrasbury Member Posts: 8,847 ✭✭✭✭✭
    I also replaced a controller as well when I first got it. I think mine is only running on battery but since it has not killed anything and has not been a problem, I have bigger fish to fry!
    I think I found one on Ebay as well...
    @rasbury Did your have the same symptom?
    Replaced the controller and same problem.  I also swapped the resistor.  Between the two fridges the problem one sees 25.5v on 110 and does not work.  The working unit sees 25.9v and works.
    The Vitrifrigo 4.2 CU fridge is a nice replacement.  Tight fit through the cabin door, but doable.
    Just saying....
    Mine did not work at all...
    Just saying....
    I bought one but had to remove the rubber moulding though
    Wild, I am trying to figure out your issue. I dont get the 25 volt. Is your compressor 12 volt? Or 24 Volt?
    Just saying....
    Ditto, thus my description of doable.  :)
    Handy,   Apparently these units are 12/24.  When you are on dc the power supply passes the 12v.  When you are on 110 the power supply out put is 24v.
    I am getting closer to finding the problem.  I scored some new help guides that I will share soon.
    Did you ever measure the voltage at the compressor itself?
    I measured at the power supply and at the controller power input.
    edited June 2017
    I need to take my Fluke meter down to the boat, i think via some guides I just posted im going to find a quick blip where voltage drops below the cut out.  My MM on the boat a Craftsman is too slow to react i think.
    Do compressor and report back
    How are you checking at the compressor?  On the 3 pins coming off the ecu?
    Yes unplug the plug and put your meter in that plug I've seen those plugs go bad before
    edited June 2017
    Swapping the ecu would have addressed if it was a faulty connector.   Unfortunatley I had the same 1 flash code again.   I also swapped out the resistor between units to confirm it wasnt a faulty resistor causing a odd cut in / out setting.    However, i will pull the plug and confirm the readings when i get back down there.
    @Handymans342
    Update:
    Swapped power supplies- still will not start
    Swapped Controllers- no start
    Checked voltage drop- .10v / 25.5-25.4. In range
    Checked continuity from pins to case/ nothing
    Checked Ohms across pins- 2.2 ohms.  In range
    Motor tries to start then immediately gets cut
    I have exhausted all troubleshooting guides.  Anyone else have another trick?  I am getting single led flash- indicating low voltage.
    The answer was right in front of me!
     I received a code on 12v and none on 110.  However the compressor still would not start.  After troubleshooting everything I came full circle back to this very statement.  Why do I have code on 12v and not 110, what if even though I'm trying to start on 110 the controller knows there is something not right on the 12v line.  I drop the 12v line from the invertor and like magic,, the compressor starts spinning!   Now I need to recharge the refrigerant as there may be a pinhole leak.  Our coldest setting dwindle over the last 2 years but a can of refrigerant every 2 years vs $1000 refrigerator I'm good with until I get other things fixed.
    Now i I need to chase out why the controller does not like my 12v connection.  Power is steady around 12.5, thinking bad breaker or loose/corroded connection.
    Good stuff Wild. Wow you have done a lot of trial! When I first got my 342 I was having trouble keeping the galley fridge cold. After cleaning out the coils and fan and repairing the gasket it has been working great but I looked in to recharging which I never did. I talked to Dometic about recharging and they said NOT to use the typical Auto Zone recharge as it contains oils that will ruin these units. It has to be straight refrigerant and has to be done right so that the pressure is not too high. The A/C tech in Rocky River that I mentioned to you could probably do that for you as well if you were going to need him for the AC.
    @Liberty44140. I have read the system is sensitive to pressure.  I planned to order straight R-134a refrigerant online but if you will shoot me your contacts info I will check with him first.  He would likely be able to pressurize the system so we can find the leak at the same time.    I feel like a fridge tech now, I know my way around each part of the danfoss bd35f system now.
