Rinker 310 engine help!!!
Tex68
Posts: 50 ✭✭
Ok I'll try and be brief. Put the boat in the water at the ramp after having charged (or so I thought) for 2 days. House battery was good but when to. Crank the engines and lots of flickering lights and bells, Vessel view flickers on and off. I did not have a warm fuzzy feeling. After trying multiple battery options including the emergency parallel switch I had "no joy". Got a boater to help me get a jump. Hooked cables up to port engine battery 1st and after a little charging got the engine to turn over and start. Then switched the cables over to starbarded engine battery to do the same for that one. I inadvertently turn the igntiIon off on the port engine killing it, went ahead and started the starboard engine with the jump, then switch the cables back to the port battery to try and jump,it again but this time I got nothing. At this point I'd taken up enough of the kind persons time so I let them go thinking I could just letting this run and hopefully charge the port engine battery. Ok this is turning out not to be brief, sorry. Anyway I pulled backed away from the dock on one engine and as soon as I put it in gear to move forward it stalled. Filnally got the local Marne to come out and they brought me 2 new batteries which is switched out (swearing and sweating was involved). Fingers cross
