sea strainers
I was told to do away with the outdrive intake and put in sea strainers with large filters.  Then just today , another guy said NO WAY..........you eliminate cooing of drives . What is the right answer ?
  • raybo3raybo3 Administrator Posts: 5,592 admin
    edited May 2017
    Think about it for a minute. If it was better to eliminate outdrive intake then Merc would have eliminated it. You can add a thru hull but you cant eliminate drive cooling.......
    Post edited by raybo3 on
    right - I have both, thru hull and drive in take come to a Y fitting that then goes to a strainer and in to the water pump. As Ray said add the thru hull if you want but don't eliminate the drive intake.
    X2 be cool
