House batteries not holding a charge
My Rinker 342 has 3 sets of batteries. I assume two batteries for port, two for starboard and the other two i know are for my house batteries. The house are 31 series batteries that were replaced 8 months ago. Both batteries there tested good. When the charger is on and connected to shore power or on the generator they show a proper voltage but then drop to around 11.8 or lower very quickly.
The issue that made me discover this is that the amps for the stereos will shut off. I can leave the boat on the shower power with charger on all week and then head out in the boat and within usually 15-20 minutes the amps will shut themselves off because of lower batteries. They do this even when im driving the boat. I thought the alternators running should be charging them and i shouldnt have that issue. I also know its not the amps that are bad because the CO Detector started beeping like it does when batteries are low.
We were on the dock overnight till monday then went out and within a few hours the batteries were low enough to cause the Co detector to go off and we werent even running the stereo at that point due to it shutting off so much.
I had both batteries tested multiple ways and they test good. Not sure where to start at.
Thanks
Thanks
I'd check the settings on the fridges. Might be able to turn them down a little to lower the load. Also look at anything you leave on over night (light in head, TV, etc.).
I also have 12V TV and antenna amp. The amp runs all the time. Granted it should be a small draw, but little stuff adds up.
Good luck.
The batteries were load tested at like an auto parts store? If you are dropping voltage that fast there is either a large load on them (stereo / amps can be the biggie) or the battery(s) are faulty. Are they filled with water too?
And yea yea for some reason each engine has two batteries. Not sure why they did that but I'm not one to change things if they are working. I think I'm going to try turning each fridge off and see how they act.
