Vacuflush Location on 360
Can anyone tell me where the vacuflush pump is on the Rinker 360 and how to access it?  I can see the black water tank in the engine room but not the pump.  Thanks.
    You can gain access in the rear birth. There is an access panel on the port side. It basically sits under the stairs. Mind you this is on a 2005 360. Not sure if they changed it on newer years post 2006.
    This one is a 2011, I found the AC pump and the sump pump on the port side under a seat cushion in the aft cabin.  I did not find any way to get under the stairs but I will look again.  It makes sense that it should be there.  Thank you.
    Interesting. My a.c. pump is under the vberth bed and shower sump is under the floor storage locker in the kitchen.
    Btw welcome to the forum. Good to have another 360 on here. Not too many of us.
    Thanks.
    I believe the vacu flush pump is integral with the toilet. @bry1429 could probably comment further on that. On my EC 360 there was a duckbill valve at the bottom of the toilet area as well. You could also probably "google" the schematic for a vacu flush toilet. The package of manuals I got from Rinker had a great schematic of the toilet and accessories.
  • bry1429bry1429 Member Posts: 371 ✭✭✭
    Not all marine toilets are identical, click the link below and pick your model for research/info.
    https://www.marinesan.com/VacuFlush-Toilet-Systems-s/214.htm
    Found it, it's behind the ice maker and cockpit fridge and towards the bow.  Thanks for comments.
