drain plug replacement
TimSImpsonTimSImpson Member Posts: 11
looking for a hull plug for a 1989 Rinker V170
This screws in anyone know where to get a replacement?
    edited June 2017
    Practically any marine dealer or marina with a store will stock them. Not an exclusive item. Just a brass threaded plug. Not sure of the size you need but quite often they're 3/4" or 1".
  • TimSImpsonTimSImpson Member Posts: 11
    OK thanks the one I have is plastic with a oring  and worn out
    Ahh, ok. Just bring the old one to the dealer and they can match it up for you. If your thru-hull is plastic, might be better to stick with plastic, if brass, go brass,
