Trim up button stopped working, then worked again. Suggestions?
Lake_Bum
Member Posts: 1,142 ✭✭✭✭
My boat is a 232, 350 Mag, Bravo 3 drive. I just completed a 3 day trip, and everything on the boat worked flawlessly, but when I got it back to the ramp, after it was on the trailer, my trim up button wouldn't work. The trailer button was the only way I could raise the drive. I tried it again once I got back home, and it worked normal! That concerns me that it could fail and not work whatsoever. After researching a few threads on here, it seems like it is either solenoids, or the wires in the actual handle.
Do you feel a solenoid could be the problem here? My gut tells me no, because I think it would either work, or not.......I am not confident enough in my electrical to hook a meter up, and test things, I don't want to fry it and make it worse haha. If it could just be in the handle, something corroded, or loose, I could handle that. Thoughts.....comments? Thanks
salt water boats maybe
most of the time it's sending units aka pucks that puke or the actual pump
- will go down just fine.
- will go up no matter what if you push the up button down to it's most pushed way down (trailer mode)
- if you are stopped, regular "trim up" doesn't work
- if you are on plane, "trim up" works flawlessly, over and over..
