alarms on 350 mag mpi
The boat went into shop for bottom paint and other upgrades this Spring after I purchased it . The 3-4 previous times of running the boat there were NO alarms. Upon putting it back in the water last Sunday after running it a couple miles or 15 minutes , the alarms came on . Oil pressure good, temp 175 both engines.  When they came on I throttled down and as boat was settling down in the water the alarms went off. I sat there a few minutes looking at gauges and decided to go on . Before boat got on plane they sounded again.  There was a lot of work and moving around in engine compartment while it was in shop. Although one major change was putting sea cocks and strainers in . I'm thinking if there was a problem with lack of water, the temps would be above 175 ??  There's suppose to be a low water pressure sensor......anyone know where it is located or anything else I should look for ??  1999 330 fiesta vee  Rinker .  Thanks guys .
  • aero3113aero3113 Member Posts: 10,007 ✭✭✭✭✭
    Did you have drive work done? Check the oil level in the reservoirs, the drives sometimes "burp" and the oil level goes down after work has been done on them.
  • sunsetsandtrailssunsetsandtrails Member Posts: 29 ✭
    Yes, we did the service on the outdrives.........they are full , actually too full . Would that cause an alarm. When I go back there, I will isolate which motor.......it never dawned on me to do that .  ROOKIE !! lol.  Thanks aero
  • rasburyrasbury Member Posts: 8,998 ✭✭✭✭✭
     yep, been there done that!
    also, on the home page the fourth post down there is a post that says "encountering faults" that may help. if not now maybe in the future
