Windlass swap
junebugjunebug Member Posts: 31 ✭✭
So I am switching my horizon 600 for a lewmar 700 pro series.  My question is can I just wire the new windlass in to run off the same switch or do I have to change everything.  The horizon appears to have the switch and relay all in one. The new one has a separate switch and relay.
    I would call Lewmar on that
  • IanIan Member Posts: 3,057 ✭✭✭✭✭
    Depends on the current draw, according to the manual the 700 draws 35A so if the switch is rated for 12VDC @35A, it should be okay. The manual also indicates a part number for the contactor suggesting it should use it and all wiring drawings use a contactor.
    When I went to a 1000 it came with relay and new switch and overload/breaker. The 600 was low enough current for the old switch to wire direct but the newer not.  If it didn't come with new and a relay it's probably okay to direct switch but as Handy suggested best to ask Lewmar.
  • junebugjunebug Member Posts: 31 ✭✭
    Ok thanks guys. It came with everything was just trying to save some work. I will call lewmar
    Let us know
    If you got it, use it! If like me you decide to add foot switches later you'll need the contactor.
    So I called Lewmar and they said I can use the old set up with no issues
