Fresh Water Pump
gackgack Member Posts: 315 ✭✭✭
Anyone tell me where the fresh water pump is on a 270FV?  Mine keep running every few minutes so may have a small leak or need adjustment to check valve if it has one.
    Mine is in the engine compartment on the forward wall.
    Check your transom shower too.
    The freshwater pump on my 2000 FV242 is in the engine room on the forward bulkhead. Mine had the same, issue turning on and off all the time, and I also suspected a leak, until the pump stopped working. Once I replaced the pump with a new one, the issue stopped.
    The pump on my 280EC is on the forward bulkhead. I had a problem with it a few years back and I used a rebuild kit on it and it works great now.
