ok i have a 06 342...How do i adjust the Cabin Door??!!!
OK its driving me nuts!  How do I adjust my sliding door...it worked perfect one day, this weekend Not so much!  Slides look ok...
    Other than cleaning the track, I found that spraying some Pledge (furniture polish) in the track makes the door move more easily.
  • IanIan Member Posts: 3,057 ✭✭✭✭✭
    I use silicon spray after cleaning off the gunk as best possible.
  • aero3113aero3113 Member Posts: 9,759 ✭✭✭✭✭
    I ended up removing the screws on the lower plastic track, after that it slides 100% better.
    On my 06 342 I use a spray lubricant on the tracks which makes it slide nicely for a month, then needs re sprayed
    A shot of WD-40 on upper and lower tracks every couple of months fixed mine.
    We had a lengthy discussion of cabin door adjustment a while back. I shifted my track a bit on one cruiser and shaved the black composite leading (starboard) "truck" on the second with excellent and lasting results. I posted what I did in that discussion.
  • mwmiller63mwmiller63 Member Posts: 9
    Bam Silicone worked like a champ!  wasted an hour for nothing!
