Trim tabs
I have a 262 BR with 496ho and bravo 3X. What will I gain if anything by adding trim tabs
    What @shawnmjr said!!!
  • toby11toby11 Member Posts: 4 ✭
    Thanks. I was wondering if it will ride better in a little rougher water
  • Lake_BumLake_Bum Member Posts: 1,143 ✭✭✭✭
    It will ride a LOT better, once you play with it a little. My 232 rides like a dream with a little adjustment in the rough stuff.
  • JoeStangJoeStang Member Posts: 1,140 ✭✭✭✭
    I use them every time out on my 276, don't even think about it just get them.
    2013 276 Cuddy ~ 350 MAG / B3
    Put 12"x12" Lenco edge mount tabs on my 232 with LED control and it is a different boat getting on plane, staying on plane at lower speed, and in rough water. Also can even out boat when load is offset to one side.
    Look at this previous thread;
    http://rinkerboats.vanillaforums.com/discussion/946/what-trim-tabs-will-fit-the-transom-of-a-2005-232-captiva#latest. You might need to go up a size for a bigger boat.
    I use mine on my 270 to level out from port to starboard depending on cross wind, passenger load etc. Still getting the hang of using them to help stay on plane at lower RPM.
    If you install them also investigate either the digital switches or a trim tab gauge. I don't have one and wish I did. I'm always second guessing what my tab position is.
    You can get a led replacement, did mine last year easy to do. Much better to operate.
    edited June 2017
    @randy56, was it one like this?
    http://alturl.com/kcifo
    Lotsa $$ for lights. Useful though.
    Thanks for the heads-up on the Hodges site @randy56. Lotsa neat stuff. Converting to CDN and adding shipping and I'm back up to $428 and that's before customs duty and taxes. We get nailed for any Provincial/State tax as if we bought the item here. Seeing all the awesome sites you guys have to choose from drives me nuts. From Overton's, Defender, Great Lakes, even West Marine, there are all kinds of great choices. Some won't ship to Canada, but even the one's that will, by the time you add shipping, duty, taxes and exchange, there's really no savings to be had.
    I'm 3 hours from the border, but I can tell you that if I ever need something really big like an out-drive, I'll be driving across to get it.
    Well that stinks, to many taxes. what if I buy and ship it to you? GEEE that's $155 more.
    That's a kind offer @randy56. Exchange right now is the big killer. 25% difference.  I think any boat bucks I have will go towards a drive rebuild in the fall.
    Any time, Rinker Bro
  • georgedafifthgeorgedafifth Member Posts: 1 ✭
    Anyone had any luck putting a Lenco Trim Tab Kit on a 2000 Captiva 212 (with Mercruiser 5.7L EFI).  There is not much real estate (at or slightly below the water line) on the transom for this kit, but need get on plain faster in smooth or rough water, and want to keep my stainless steel prop for top end speed.
    Here are my smart tabs on a 2002 212 if it helps any. They are a big help...
    Dave
