ok what would you check next?
davidbrooks
Member Posts: 1,427 ✭✭✭✭
So at the beginning of spring i was able to get up to 39mph and 44-4600 rpm. Now i can barely hit 30mph and i am really struggling to get up on plane. At best i get to 4000 rpm. Seemed to do act the same with 1/4 tank of gas or full tank. I checked and i don't have any codes on the pcm and it is full power available. I just did a tune up with plugs, wires, rotor and cap. The old plugs looked pretty uniform. I have a 2003 342 with Merc 350 engines with 450 hrs on them.
I felt a little bit of growth on the bottom but not too bad. I would also think that it wouldn't have an affect of 10 mph like i am seeing. Throttle cables? If so what advice do you have on how they should be adjusted. Compression? I would of thought i would of seen something different on the plugs? Air leak? Ugh. You know you are frustrated when you start thinking about just buying new engines.
