Fuel capacity on 1989 Fiesta Vee 250
botsy2017botsy2017 Member Posts: 3
Can anyone help can not find capacity anywhere?
  • BoatmanBoatman Member Posts: 26
    Brief Summary
    The new 250 Fiesta Vee immediately stands out as a "stretch" version of the express cruiser concept. Its uncluttered, single-level cockpit seems the size of most deckboats and its an inviting walk from swimplatform right on up to the cabin.
    Key Features
    You won't go wanting for seating room in the 250, which features a double-wide helm seat with flip-up bolster, wrap-around portside lounge, and nearly full-beam aft bench seat. The wetbar in the cockpit comes complete with freshwater sink, trash bin, and 25-quart Igloo cooler so no one has to run down to the galley for refreshments. Speaking of the galley, the 250's has a standard undercounter refrigerator/freezer, sink, alcohol/electric stove, and microwave oven. The dinette is fully forward with U-shaped seating for four, and the table drops down to create a double berth. A second double is located in the mid-cabin, and that, combined with a fully enclosed head/shower make the 250 Fiesta Vee an exciting new addition to your express cruiser choices.
    Specifications
    Length Overall27'1''
    Beam8'6''
    Dry Weight6,350 lbs.
    Tested WeightN/A
    Draft3'0''
    - Draft UpN/A
    - Draft DownN/A
    - Air DraftN/A
    Deadrise/Transom18 deg.
    Max Headroom6'0''
    Bridge Clearance6'10''
    Weight CapacityN/A
    Person CapacityN/A
    Fuel Capacity75 gal.
    Water Capacity33 gal.
    Length on TrailerN/A
    Height on TrailerN/A
    Trailer WeightN/A
    Total Weight
    (Trailer, Boat, & Engine)
    N/A
    Prices, features, designs, and equipment are subject to change. Please see your local dealer or visit the builder's website for the latest information available on this boat model.
    Engine Options
    Std. Power1 x 220-hp MerCruiser 5.0L Alpha One gas sterndrive
    Tested Power 1 x 300-hp MerCruiser 350 MAG MPI
    Opt. PowerVarious MerCruiser sterndrives up to 1x320-hp
    1 x 320-hp MerCruiser 6.2MX Bravo 3
    Test Results - Change Measurement Unit
    RPM MPHKnotsGPHMPGNMPGStat. MileNMdBa
    650 3.42.91.03.42.922619764
    1000 5.44.71.53.73.225121971
    1500 6.75.82.62.62.317715469
    2000 8.57.35.01.71.51149974
    2500 11.39.87.51.51.31028979
    3000 18.416.08.52.21.914712780
    3500 26.823.310.52.62.217315081
    4000 32.828.513.02.52.217114982
    4500 37.932.916.72.32.015313384
    5000 41.636.221.81.91.712911288
    RPMNMKMKPHLPHKPLdBA
    650 1973645.503.791.4264
    1000 2194048.705.681.5871
    1500 15428510.809.841.1269
    2000 9918313.7018.930.7274
    2500 8916418.2028.390.6579
    3000 12723729.6032.180.9280
    3500 15027843.1039.751.0981
    4000 14927552.8049.211.0882
    4500 13324661.0063.220.9784
    5000 11220866.9082.520.8188
    All fuel consumption numbers are the total for all engines in the boat. Speeds are measured with Stalker ProSports radar gun or GPS. Fuel consumption (gallons per hour) measured with Floscan digital fuel-flow meter or by on-board factory-installed diagnostic instruments. Range is based on 90% of published fuel capacity. Sound levels determined using Radio Shack digital decibel meter on A scale. 68 dBA is the level of normal conversation. Time to plane is measured from start of acceleration to formation of rooster tail behind boat.
    Performance Chart
    Performance Chart
    Acceleration Times & Test Conditions
    Time To Plane5.5 sec.
    0 to 3010.9 sec.
    Ratio2.2 : 1
    Props22''
    Load2 persons, full fuel, full water, min. gear
    Climate80 deg., 88% humid.; wind: 0-3 knots; seas: calm
    Rinker 250 Fiesta Vee (Not in Production) Line Drawing
  • botsy2017botsy2017 Member Posts: 3
    I don't think it holds 75 gallons. I filled it up to full and the pump I think said 44 gallon so I think it has to be somewhere around 50 gallons.
    Is your gas gauge accurate? The specs @Boatman posted look right out of a magazine and my FV270 takes 100 Gallons, so 75 for your 250 sounds about right.
  • prgrod01prgrod01 Member Posts: 53 ✭✭
    My 2001 242 is 75 gallons
    2001 Rinker 242
    edited July 2017
    The specs Boatman posted look legit to me. 2006 FV250's have 70 gallon tanks. I don't think 50 gallons would be adequate considering the fuel burn rate. How did you determine the tank was near empty when you put in the 44 gals?
    Andy
    I was at about 1/8 on the gauge and it was showing full after 44 gallons
    My fuel guage moves very slow compared to the gas I pump in.  Almost like 20 gallons moves the needle a little bit.
    2002 - 270FV Mag 350 B3
    edited July 2017
    My gas gauge shows one quarter of a tank and I've used 36 gallons according to my fuel flow meter and I know my tank holds a bit over 70 gallons because I had a new one built from scratch.
    My mechanic blames the inaccuracy on the "V" shape bottoms of the tank and the sender being better suited to squarer automotive tank applications, plus boat often do not sit level. Not sure about that, but my distrust of the factory gas gauge led me to install a fuel flow gauge by Floscan. Great peace of mind knowing a) how much fuel per hour you are burning and, b) how much fuel has been consumed.
    Andy
