Waxing the hill and topside
it's been a few years since I waxed my boat, some slight oxidation present.  Can someone lend their opinion on getting the mirror finish back? What wax, or compound and wax to use?
thanks
    edited July 2017
    Do your self and body a favor and hire a good detailer. You won't regret it
    wet 1500~2000 grit sandpaper.  lightly.  oxidation gone quickly.  rinse well.  rinse again just in case.
    then- wax.... and a technique i learned about two weeks ago works very well- it was called "bending it in".
    real simple:
    with paste wax pad in one hand (i used carnuba) and the buffer in the other at mid speed setting and a finishing pad, wipe the wax on in a small area... BEFORE IT DRIES buff it.  if you've done it right you will see the lines of the wax 'bend' as it's being jammed in the pores.... and that's what it's about- making that surface smooth as literal glass by filling the microscopic cracks with wax.... it takes likely five minutes to apply two full coats to a 3'x3' area.
    one for the fiber, another for the glass- and the last for vanity.  the third coat after buffing the second and allowing it to stand while you work other sections.... this technique is amazing.
    after being instructed on this method, I now understand how pro's can do it so quickly with such outstanding results.  you don't let the wax stand.  you 'bend it in' wet.  it defies every instruction i've ever heard prior.  it flat out works.
    Its easy. Get 3m super duty compound ( black bottle) . Use a wool buffing pad about 3000 rpms, apply Collinite ( wax only) when you are done. You will be shocked at results.
    This is assuming you know how to use a buffer the right way also....
  • mskpharmdmskpharmd Member Posts: 44 ✭✭
    Thanks guys!
  • IanIan Member Posts: 3,062 ✭✭✭✭✭
    What about the topside non-slip? Not something you'd "buff up" but still appears like it needs work despite regular cleaning. Any ideas?
    A good solid pressure wash on the anti-skid should do it.....
    for stubborn discolor/stains on the no-skid, Starbrite makes a great product.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,924 mod
    I use this as well (& it has ptef in it to give somewhat a nice finish).  Mary Kate also has a nice non-skid cleaner.  For the swim platform, I sometimes just use barkeeper's friend since runoff doesn't go all over the boat.
    Thanks guys, powerwash had been suggested before so that may be the first try. I'll have to check a non-skid product I do have a bottle of, brown goop that seemed to do little.
    I got this information from an old member here.  I follow it on my blue hull and get compliments all the time.  Now its just upkeep.
    http://forums.sbo.sailboatowners.com/showthread.php?t=117266
    Patrick
    06 Rinker 270
