Voltage and Trim gauge not working on 2007 280 EC
TomEkenes
Member Posts: 6 ✭
Hi
I have problems not getting any readings on the voltmeter, nor the trim gauge. Fuel, oil and temp as well as background light on gauge are working, but not the volts. The trim gauge also have lights, but not responding when trimming the engine up or down.
Found a wiring diagram on the forum I assume is for my model
It seems to me that the Voltmeter is connected to the trim gauge.
Im not experienced in troubleshooting problems of this sort. Not knowing where to start. Have taken out the gauge and looked behind it, but not sure where I should start investigating. Is it most likely that the gauge with volt needs to be replaced or am I looking at the wrong place.
Appreciate for any suggestions on how to proceed with solving this.
Br Tom (Norway)
Br Tom (Norway)
http://rinkerboats.vanillaforums.com/discussion/3038/280-ec-wiring-diagram#latest
I measured the connectors going into the gauges. Don`t know if the gauges can be measured in a way?.
However, the results I found starting with the Trim gauge:
A: Against C, ignition on measured 5,6
B: Against C, ignition on, switch on measured 12,73
C: Ground
D : Against C, Ignition on and tilted measured range 0,01-0,04. Turned on engine and tilted measured range 0,10-0,11
I expected D to be higher, so my though is that the problem with the trim gauge is somewhere else not sending signals to the connector?.
Going to the 4 in 1 gauge:
a: Against c, ignition on measured 12,3 (ignition pwr)
b: Against c, ignition on, switch on measured 5,6 (panel lights)
c: Ground
d: Against c, ignition on measured 0, engine on measured 0,04 (Oil pressure, gauge is working and giving correct readings)
e: Against c, ignition on measured 0, engine on measured 0,04 (Temperature, gauge is working and giving correct readings)
B: Against c, ignition on 0,01 (Fuel tank, gauge is working and giving correct readings)
Now Im confused since I expected readings on the Oil, temp and Fuel readings, so I assume I went wrong somewhere here. I have measured at least 3 times on all connections giving the same results as presented here.
What I still dont get, what are giving signals to the voltmeter?.
Also attaching the connectors and have "dotted" the ones I assume is OK with GREEN based on the electrical readings, and RED on the ones I didnt get the reading I expected. I dont know if it is helpful:
Connector 7 and 8 are OK it seems:
Connector 9 is strange based on the readings.
My problem right now is that im not able to conclude since I dont understand the results I got.
Since you have been helpful I wanted to present the results, hoping someone with a better knowledge about electrical wiring can draw some conclusion and point me in a direction. I also wanted to post the results as a feedback since you invested time in my post.
Br Tom
Trying once more:
Starting with the Trim investigation:
I measured the following: (Not saying I have done it correctly, but here`s what I did and the results:
A: Against C, readings where 5,6 with ignition on
B: Against C, readings where 12,73 with ignition ON, and turning on panel light switch
C: Ground
D : Against C, reading when ignition on 0,01-0,04 running the Trim up and down. Also tried with the motor running, the readings where 0,10-0,11 when running the Trim up and down.
Should I have gotten higher readings in the connectorplug?
a: Against c, readings 12,3 with ignition on (Ignition?)
b: Against c, readings 5,6 with ignition and switch on (Lights)
d: Against c, readings 0,00 with ignition on, engine on 0,04 (OilP, working in the gauge though)
e: Against c, readings 0,00 with ignition on, engine on 0,04 (Temp, working in the gauge)
B: Against c, readings 0,01 with ignition on (Fuel, working in the gauge)
So Im a bit confused since I was expecting to get readings on the fuel, oil and temp, since they are working perfectly.
Still dont understand where the Volt should be coming from or how to measure if it gets signal.
Based on the results and lack of knowledge I cannot conclude if the gauges are faulty or the wiring needs to be looked at further.
Also showing the connectors where I have noted my finding with green dots for the ones that seems OK, and red dots for the ones that either doesnt work properly, or I havent measured correctly
Connector 7 and 8 are used in the wiring diagram
and
Connector 9 and 12, where 9 is the one with the red dots.
5,6 was voltage on panel light switch on both gauges.
a on Trim and B on 4-1 Gauge. Not sure why is has such low voltage there.
