270 Fiesta Vee Sink drain elbow help
04FV270riverrat
Member Posts: 268 ✭✭✭
So my 2004 270 FV started to soak the cabin floor between the fridge and bathroom door with water only when put on the trailer and pulled out of the water (front end is lower than in water). I suspected the water hoses were leaking so I pulled the little toilet paper cubby out and found some surprising stuff! Not only were both hot and cold water lines leaking at the stainless steel/nylon adapter, but my drains 90 degree elbow was broken and the drain hose not even attached! Does anyone know where to find the 90 degree elbow? It looks to be about 1 5/16" inside diameter where it screw onto the sink drain. Do I need to replace the whole drain assembly to fix this?
