How to Fuse When Changing Over to LED Nav Lights
rmrstlmormrstlmo Member Posts: 238 ✭✭✭
I need to replace one of my nav lights so I'm planning on switching LED lights. I have 2000 340 with the in dash small round breakers. The lights require a 1 amp fuse and the smallest breaker that I have found is 3 amp. I know I could use an inline fuse. Any other ideas? Ray
Ray
2006 390
Previous 2000 340
    Ray,
    I'd use the 3 amp breaker and call it a day.   As long as the wiring size can handle the current,  you should be fine.   If you develop a short,  the breaker will protect the system. Like you say,  you can always add a 1 amp in line for added protection.
    Mark
    2019 MTX20 Extreme
    If only changing one light, watch reducing the fuse. You might end up popping it from the draw from the non- LED light.  I agree with MVN on this!
    edited June 2013
    Please see this post.   It's technical but very informative.   The breaker size is a function of the wire ampacity to the load.
    Oops....
    Mark
    2019 MTX20 Extreme
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    Mark,
      Did you mean to put a link in your response?
    Ray
    2006 390
    Previous 2000 340
  • john744john744 Member Posts: 35 ✭✭
    He's right about the purpose of the breaker.  In the wiring circuit, the breaker is there to prevent a fire FIRST, damage to the load second.  Since excessive current draw will create heat in the wire, too much current may cause the insulating material to melt or to ignite (depending on what it's made of).  The breakers PRIMARY purpose is to prevent this by limiting the amount of current allowed to flow in a circuit, based on the current capacity of the wire. If your concern is for the load, add a properly sized fuse close to the load itself.  This will prevent any other device in the circuit from drawing current in excess of the fuse capacity.
    Short answer - Leave it alone.
    John & Kathy
    2002 FV 310 "pair*a*dox"
    rmrstlmo said:
    Mark,
    Link added to post.
    2019 MTX20 Extreme
