Dash Panel Rocker Switches & Printed Actuators Found !!!!
john744john744 Member Posts: 35 ✭✭
Hello Guys and Gals ................
Every Once in while, someone pipes up with a question regarding the dash panel rocker switches.  If you are like me, the switches are fine, but the actuators are faded beyond any hope of reading.  I happened upon a source for both the switch bodies and PRINTED Actuators.
PRINTED ACTUATORS   $2.25 each !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.searay-parts.com/SearchResults.asp?Search=actuators
Switches - Carlingswitch Contura II - Manufacturers Web Page (Detailed Information)
http://www.carlingtech.com/rocker-switches-v-series-ii-iii
Digi-Key has a good selection of V-Series switches in stock
http://www.digikey.com/scripts/dksearch/dksus.dll?s=55&FV=fff40011%2Cfff8005c%2Cfffc01b0&mnonly=0&newproducts=0&ColumnSort=0&page=1&chp=0&quantity=0&ptm=0&fid=0&pageSize=25
Available from Allied Electronics, approximate cost $7 - $14 each
These stock units have RED & GREEN LED illumination vs the incandescent switches provided from Rinker.
Switches come in various circuit configurations
Switch, Rocker, V SERIES, Lighted, DPDT, (ON)-OFF-(ON)   $14.10 ea  MOM - OFF - MOM
http://www.alliedelec.com/search/productdetail.aspx?SKU=70131622#tab=specs
Switch, Rocker, V SERIES, Lighted, SPDT, ON-OFF-ON       $10.10 ea
http://www.alliedelec.com/search/productdetail.aspx?SKU=70131621
Switch, Rocker, V SERIES, Lighted, SPST, (ON)-NONE-OFF   $9.98 ea  MOMENTARY
http://www.alliedelec.com/search/productdetail.aspx?SKU=70131619
Switch, Rocker, V SERIES, Lighted, SPST, ON-NONE-OFF     $6.87 ea
http://www.alliedelec.com/search/productdetail.aspx?SKU=70131618
Available from Newark Electronics
A little more expensive, $13 - $20 ea, but some different circuit configurations.
http://www.newark.com/jsp/search/browse.jsp?N=2203+201896+502&Ntk=brand|gensearch&Ntt=CARLING|v*&Ntx=mode+matchallpartial
SWITCH, ROCKER, SPST, 20A, (JUMPERS)    $18.21
http://www.newark.com/carling-technologies/vgd2ghnb-aac00-000/switch-rocker-spst-20a-black/dp/76K1068
John & Kathy
2002 FV 310 "pair*a*dox"
  • mambugmambug Member Posts: 24
    I got in here excitedly thinking maybe the dash these switches go on would be in a link here.
    Alas, it was not meant to be...
  • john744john744 Member Posts: 35 ✭✭
    I'll have to work on that ............................ mine's all faded & cracked
    John & Kathy
    We're thinking of fabbing our own now. I have a thread on here about looking for a replacement, and getting the run around by Rinker.
    There are a lot of faded and cracked dash panels (switch and instrument) out there that are in poor condition.  If you find someone who can fab them, there might be some interest among the members.  Mine are functionally intact, but I would consider replacing them if a reasonable replacement was available................
    John & Kathy
    Great post John. Thanks for the effort to share these. Mike
  • trich11trich11 Member Posts: 108 ✭✭✭
    Anyone out there had a dash cover made? Some of the older Rinkers and Formulas came with one. I keep towels over mine when not in use.
    I've copied this great info over to the RBO Archive section for reference purposes.
    Mark
    2019 MTX20 Extreme
    I use the towel cover also ... I like the idea of a dash cover
    Trich,
    I had a dash cover made early on.  To me this is the most valuable piece of canvas on the boat.
    Tony
    Salt Shaker 342
    Just a word of CAUTION ----  Be careful when selecting switches.  Within the CONTURA Series, there are basically 2 different size units, each with lots of options.  The 8 terminal unit is what I have on my 2002 FV 310 and drops right in to the hole in the dash panel, but there is also a 10 terminal unit which is slightly larger.  With the 15 part number it's easy to mess these up.  (Example uses 4 first digits only ...)
    Example 1:   V1D1  V=Series   1=SPST    D=20A 12VDC     1=8 term .250 tabs no barrier
    Example 2:   V1D2  V=Series   1=SPST    D=20A 12VDC     1=10 term .250 tabs no barrier
    What's really important is the 4th digit of the part number.  It must = 1 or J   (8 terminal switch assy)
    See Page 10  (Contura II Switch Part Numbers)   http://www.carlingtech.com/sites/default/files/documents/V-Series_Details_%26_COS_032213.pdf
    Digi-Key Electronics web site catalog page for contura switches
    http://www.digikey.com/scripts/dksearch/dksus.dll?s=55&FV=fff40011%2Cfff8005c&k=carlingswitch+v+series&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
    John & Kathy
