Question: Are the hulls of the FV270 the 280EC and the newer 290 the exact same?
tk1973
Member Posts: 122 ✭✭
I know the widths are the same at 9'1" but wondering if they all shared the same hull and design.
Reason I'm asking is that I'm trying to setup my bunk trailer for my 280 and saw a great post from Mike a.k.a TikiHut with some measurements for his FV270 in the trailering forum.
https://rinkerboats.vanillaforums.com/discussion/3088/fv270-tri-axle-trailer-set-up-and-dimensions
Hoping that someone can chime in and let me know if the hulls are the same as that would make it easier in setting p this bunks in the rear as per his instructions.
Thanks in advance.
On a bit of a side note, it looks like my Gimbal bearing is bad, and growling sometimes when I try to trim up. Figure I'll just do a transom kit and replace the bellows at the same time in a few weeks. Hoping to squeeze one more run out of her maybe this weekend and then done for the season.
Thanks in advance.
Guess I'll wait for Greg to get me his old measurements.
Just to be clear you meant 47 and not 57" inches from center to center.
Only reason im double checking is from Mikes post for his fv270 his widths from center look approx 57"
