speedomter tubing
rasbury
Posts: 8,956 ✭✭✭✭✭
Hey, sitting here with out much else to do.....I mentioned on my bellows post that it appeared that my speedo tube connection on the back side of the transom appeared to be broken off. I looked in the manual which is pretty vague about it, but it seems to say that the tube is pushed through the transom and is all one piece to the speedometer itself? It looks like from what I'm seeing, and perhaps it is for something else entirely, like a tubing that looks like it and it connected to a part that looks like a nylon piece...it is broken off and a barb is inside the tubing....what's the deal on this? Could this be where my leak was coming through? 270 with the bravo III. Not having pulled a motor myself (yet) and looking back there, it's hard to tell. I'm sure the manual is clear as day for someone that has pulled the motor out before...
Best Answers
davidbrooks
Posts: 1,431 ✭✭✭✭
possible but the leak would be so tiny that it is hard to imagine it being noticeable. I took mine off at the transom and speedo and tried to blow air through it. Nope. Clogged. Cleared that out then tried to clear out the remainder. It is a pain and i was happy to just abandon it. One thing i realized when replacing the center underwater light on my boat was that when i fished the new wire in the transom had a hollow section in the middle. The wire went in from the back and then down before it popped out. I started getting a little worried i was getting a small leak there and it was coming down in between two transom walls. For me though i could see calcification on the transom assembly around the steering linkage. So that was my first sign. I think from what you have said so far you really needed to do this work. I wouldn't look back at it and second guess it.It's 5 O'Clock Somewhere! -
reneechris14
Posts: 3,134 ✭✭✭✭✭
@ras it is a quick disconnect squeeze and pull, yes if not connected it will leak but if your hole in your drive is clogged not it will not leak. I'll try to find I pic2005 Rinker FV342 Pawcatuck river,Ct -
rasbury
Posts: 8,956 ✭✭✭✭✭
Well I could see something there....and it's broke off in the tube. I'm not sure if it stopped working when they pulled the motor or if before at some point....I need to get it in the water and better identify it...thanks, -
Lake_Bum
Posts: 1,141 ✭✭✭✭
That information is correct. On my Dad's old Cobalt, the speedo got disconnected from the gauge under the dash, and it would leak right onto your feet! If there is a break, anywhere in that line.......leakrasbury said:so @davidbrooks would you think if it was not connected on the inside of the boat, would it leak? I saw that just as I was taking my boat to storage before the storm hit us here in central Florida- I will scream if that was the cause not that my bellows did not need to be done anyway....
one at the leg
one at engine and one by cluster
trasom assembly
beaides all the aftermarket stuff
