Trim Sending units
rasbury
Member Posts: 8,855 ✭✭✭✭✭
OK- storm is passed and time to get back to work on my boat from the bellows replacement. Before life hit the fan, including a little storm on 9/11 here in Florida, I got my outdrive back on but have run into issues with my trim sensors.
While I did remove the pivot pins and re install and understand they are not exactly in the same place they came out of, everything should work I would think although I would expect them to be off.
I had the drive down when I took the sensors off, and the drive down when I attempted to put them back on. The gauge is pegged to full up. I did not play with the sensors like to turn them to change the settings from where they came off.
I installed the trim limit sensor first and followed the instruction with the manual- I lined up the little lines on the wheel with the sensor body and installed per the instruction. It should have hit limit way before where I would want it but it went all the way up to I assume the trailer position.
So, I proceeded to the position sensor to see if I got anything out of that one, followed the book and the gauge does not move and is pegged up. Even though I know I did not move the part that turns inside the sensor, I played with it now to see if it was off somehow and turning made no difference to the gauge.
What happened on this? While for the most part for trimming while running I don't really use the gauge anyway and go by sound. I'm more concerned about some of the shallow water I get into and don't want to trim it up to high and lose my water pick up and water pump!
@rasbury , maybe your meter probe/wires can fit through the drain hole? If not you can make long jumper wires with alligator clips on each end.
