bravo III steering seal leak- advice needed.
skennelly
Member Posts: 2,196 ✭✭✭✭
Back story. Winter of 2016 I had a gimbal ring, upper shaft and seal replaced. Ever since I still noticed water in the bilge and this season determined that the steering area was wet. At the beginning of this season Spring 2017 I told my boat shop about it and they said they would look at it when fall came.
well fall has come and they just looked at it and got back to me. Said that the new upper pin they installed has pitting and corrosion on it and that they contacted mercruiser and mercruiser said there might be an electrolysis issue????
Here is the new pin they installed in Winter of 2016 and now are saying it's corroded and causing the leak to continue.
This just seems very weird to me.
2002 - 270FV Mag 350 B3
Seems maybe they damaged seal when installing or forgot a seal or bushing when installing.......
If you take a look at where the seal is located it seem to have groove the shaft, in one year.......
They haven't told me they wouldn't fix it yet...but now I have my doubts about their entire business. Really shi$$y feeling.
The manual states "6. Tighten locknut until a clearance of .002 - .010 in. (0.05 - 0.25 mm) exists between lower swivel pin washer and gimbal housing mount." so it's tight and shouldn't let water through. When I did mine I wasn;t sure what sealed this and had to search for it, not on the gimbal ring drawing but the housing drawing so without a careful look I could have missed it. And the old wasn't obvious either in seeing it there.
Push as a warranty item, even if that pitting is real and a bigger issue, I wouldn't expect leaking immediately after, you'd have only see it over time.
Well mid season I pulled the boat to clean and and was awe struck at what I saw on the drives and bottom. My bottom was painted with the ablative copper stuff. The zincs were basically totally wasted off, had this rust like electrolysis coating on all my props and the bottom of the bottom even had what almost looked like a burn mark in the paint on the bottom. Then I started thinkin man there has to be something electrical going on here and then it dawned on me about the radio issue. Well I went to pull the battery switch panel because one of the switches wasnt working right and I discovered a fuse holder and ground wire behind there that the previous owner tied in for the radio. Well apparently the fuse holder some how got exposed to ground and was back feeding power to ground through the output wire. I removed and replace the wiring and fuse and put it all back together and removed my new feed wire and bam everything back to normal. It was crazy what just a couple volts of electricity getting into the ground system can do. I would look in that direction. Possibly they didnt reconnect the ground straps on the transom plate when they did it too. Good luck !
I'm assuming they will check the mercathode system during their investigation into their theory that it's electrolysys
They replaced under warranty
1. Steering tiller arm
2. Upper steering shaft ( steering pin)
3. Steering shaft seal.
It all looks good to me now. We'll see when we splash in next Spring.
