Running AC out of the water
frenchship
Member Posts: 1,079 ✭✭✭
Hi,
I need to run my AC with the boat out of the water for troubleshooting . The boat is on his trailer I can not used the type of toilet plunger on the intake it is to closed of trailer bunk. If I used a garden hose to feed the pump should it be on on full blast or used moderate pressure ?
Thanks
Paul
Thanks
Paul
Best Answers
Member Posts: 2,989 ✭✭✭✭
Just watch the 2 small plugs on the pump that they aren’t popped out by pressure. A few years ago the marina pumped the pink goop a little strong and these popped out and so startup had water bubbling out when sea coco opened. Luckily I found them in the hull when cleaning up things.Post edited by Ian on -
randy56
Member Posts: 4,085 ✭✭✭✭✭
Just installed a new AC pump, about 3 weeks ago it was a 580 GPH pump. To give you an idea.A 1/2-inch garden hose delivers about 9 gallons of water per minute. The standard 5/8-inch garden hose delivers 17 gallons per minute. Larger hoses, such as a 3/4-inch hose, use up to 23 gallons per minute. The average water pressure for your garden's hose bib produces about 40 psi (pounds per square inch).Boat Name : -
Michael T
Member Posts: 7,235 ✭✭✭✭✭
.....as long as you have a steady stream of water coming out the discharge hole in the hull you will be fine. I'd say coming out about 12" from the hull would be plenty.
Paul
