Ideas for using DampRid
Willhound
Member Posts: 4,242 ✭✭✭✭✭
Depending on snow levels this winter, access to the boat under cover might be difficult. Outside storage, and not plowed. In a perfect world, I'll use DampRid in the cabin set inside a pail that I can empty from time to time. If I can't get to it....
I had thought about putting the containers in the sinks and just letting the water drain out, but the package clearly states to not let contents contact metal..makes sense, I could see the Calcium and Potassiuim Chloride having an adverse effect. What do any of you do? Just get an extra, extra large tub? Had thought about rigging a drain hose into a bucket and stuffing it down the drain....probably not good for the hull finish below the thru-hull....
bag version works but will burst if not checked frequently lol
They normally don't fill to the point of overflowing. If you're concerned, there's a few options like just put more than 1 in the cabin, put 2 or 3 spread out. They'll each take out a portion of water, and they shouldn't fill up, not all 3, that'd be a tonne of moisture.
The other option is to put them in a larger container, just in case they do overflow. So think of a bucket in a bucket.
Once I covered my boat, I would not want to go back in. Actually opening and closing can introduce moisture.
or other odors.
ac is good to control humidity but if someThing ruptures look out. Bulge pumps better be ready.
Just one thing to note, if it does overflow ... you're crystals are also done. So you actually want to make sure you have more crystals than water ... if you think you're going to overflow, then you need a bigger bucket of crystals or more buckets.
