Jabsco Manual Head Replacement
rwirerwire Member Posts: 12 ✭✭
Hi,
I'm looking to change from a manual head to an electric one.
Jabsco makes one called a Lite-Flush. They say it's a direct replacement for the manual head.
I was wondering if anyone has installed one and is it as easy as they make it sound.
Thank You
2005 FV250
    As Al stated in an earlier post on this subject you need to have a separate circuit for it. Do a search you'll find the discussion
  • skidrowskidrow Member Posts: 45 ✭✭
    Did the conversion late last summer....works great and does
    fit the existing holes..had to pull out the toilet paper roll area to gain access underneath
    the toilet...went for the optional push button flush/fill buttons and mounted them under the sink.
    Also put in an on/off switch on top of the toilet paper rolll area. Hardest part was pulling the wires
    from the toilet to a 12 V source.. Good luck.
  • rwirerwire Member Posts: 12 ✭✭
