The oil drain hose that slides through the bildge plug hole had a small thin clamp on it that come off. It looks like it was crimped on. Any idea how to replace this?
I have the hose but I don't run it through the drain hole- I have a pump I attached to my drill and put the hose with the pump down into the hose that goes to the pan so I get all the oil out- easier than jamming the hose down through the fill...my other boat had the swivel like mentioned above and pulled out with the drain plug- since I store without the plug in the boat, this works best for me.
it might be getting old and saturated with oil.
you don’t want to dump oil into your bulge while running
so if you want to change you will have to do it while changing oil
