Any issues with Spotlight on 342FV?
canaan
Member Posts: 22 ✭✭
First season with my 2006 342FV. When I took possession mid summer, the spotlight worked fine. Now the light works, but it doesn't move up or down or rotate. Electrical issue maybe? Just wandering if anyone else has experienced this (light works, no movement)?
Best Answers
Stodge
Member Posts: 2,738 ✭✭✭✭
Did you check the fuses in the switch? There should be 2 raised rectangles on the control switch which are actually fuse covers for blade fuses. Might want to take a look there.
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
If it's not the fuses I would take apart the switch to make sure everything is good, then try up front at the motor. Shouldn't be too hard to get to the wires.07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
Stodge
Mine quit working because someone (before I owned her) had re-routed the ground connection from the switch and it had gotten loose. But when that happened it was totally dead.2002 FV 342 on Lake St. Clair - Past Commodore SHC - Vessel Examiner USCGAUX
