Galley pump inop???
denniscarguy
Member Posts: 5 ✭
I have a 2008 246 cuddy with the galley pump, sink and transom shower. Last year it was winterized. This year when going to flush it and put nfresh water in I could not get the water to flow. I can hear the pump working. I filled it with water to get pressure. However, I still get no water coming out of either device. Any suggestions?
Where is the filter?
How would I prime it?
Thanks in advance...
There is a valve between the fresh water tank and the pump on my 2006 EC 250. If you have one, check to see if it is closed. I had the exact same problem this year. That valve just needed to be opened.
I agree with UtahEd and before you start check all your lines for a kink that could prevent priming.
I miss it and tried to prime for over an hour when it was the hose kinked.
