Solar battery charger
LaRea
Member, Moderator Posts: 8,030 mod
Anybody have recommendations for a solar charger to keep my house battery charged during winter storage?
I'll be in a spot where they won't let me leave shore power connected to the boat. I don't want to disconnect the house battery, because then I'd have to manually close and open the engine hatch every time. And I can't leave the battery connected because parasitic loads would drain it within a week.
My plan is to disconnect the starter batteries, and use a solar charger for the house bank. I'm going to measure the parasitic load (current used by GPS receivers and other devices when everything else is turned off). That will tell me what size panel to get, and whether I need a regulator.
I guess the only issue would be if or when we'd get snow. You'd have to have the panels reachable to clean off, but yet not hidden by shade of your boat or anyone else's (might be tough). I know someone that had a 75W one they set out on the bow of their 400 and it just plugged into their cig lighter (right at their dash). Seemed to keep things working pretty well and no regulator. For parasitic loads, I'd think something small like that without a regulator is all you'd need.
How are you covering your boat? I'm asking because I'd think you could leave your engine room open with a cover or shrinkwrap on it? I know my hatch will open with my cover on it (I do it all the time in the winter). Then, you could leave all batteries disconnected (reconnect house in winter when you tinker around on boat).
For that rare snow cover that lasts longer than a couple days, I'll go check the boat anyway, so I can clear off the solar panel.
I'll measure the parasitic load tomorrow while I am (heavy sigh) hauling and blocking the boat for winter.
CO detectors, memory items like radio and GPS, also Genny electronics can pull some, but that switch should be off. Other things like little green light in the fridges (not sure how to get them off, breaker and 12VDC and knob inside all off)...
I guess when you test the parasitic load, turn the battery switch off as well and see what changes.
And if you have the Mercathode system on-board it is wired direct also, not switched so draws all the time that batteries are hooked up.
@Liberty44140 - I will definitely try that tomorrow!
For my 2007 370, the "Easter egg" is:
* shore power connected
* battery charger on
* stbd battery switch on
* helm power switch on
So, I do not need a solar panel for winter storage. @Liberty44140 - if you ever come to the DC area, I'm buying you a beer (or two).
