First time changing the Impeller
joey91279
Posts: 19 ✭✭
Hi Rinker friends,
I will attempt to change my first impeller this spring on my 2005 Captiva 192. I was wondering if the job is difficult and I will be able to do it on my own or do I need to take it in and have a professional do it. I do watch a lot of youtube videos on how to do things on the boat.
I do appreciate any feedback or help!
Thanks,
J
Thanks,
J
The difficulty depends a lot on your boat and how hard it is to physically reach the pump. Maybe some other 192 owners will chime in with details.
If you need to change the impeller while the boat is in the water, here's a trick. When you remove the hose that supplies water to the pump, sea water will start flowing out into the bilge. Don't panic! Just stuff a rag into the hose to stop the water flow. Make sure it's tight enough to stay in place until you finish the repair. You might end up with a gallon or two of water in the boat, so turn on the bilge pump.
Oh, and maybe take a photo of the serpentine belt before you remove it.
everything else is pump housing related.
just get a merc or Sierra kit and you will be just fine.
Dave
Moon Township, PA - boating in the Ohio River
