oil extractor pump
GMSLITHO
Member Posts: 1,618 ✭✭✭✭
Can anyone recommend one
GMSLITHO
That's what I use
once drained I flick the bilge pump and enjoy a cold drink.
like 8 for every quart I dumped lol
If I were going to keep a boat for any length of time I would remove the drain plug from the oil pan and install a brass fitting. I listed all the part numbers for the different oil pans a couple of years ago. I would attach a purpose built oil/heat resistant hose to it and then an electric oil pump. Using this removes the oil in a couple of minutes.
The first one I had installed on a boat was in 1994. The technician said I was wasting my time. He said the system used by the marina (a white pail with a pump on top - everyone has seen these, right?) would have gotten everything but a few ounces.
I told him I doubted that. He pulled the drain plug and started yelling for rags. He burned his hand as hot oi ran all over it (we had - obviously - heated the oil before removal to draw all contaminants into the oil) .....and about a pint of oil drained out.
Anyone who thinks they are getting all of the oil out via a dip stick removal system is dreaming.
For a few bucks and 30 minutes work install a proper removal system.
