is there anyway to replace the fluid in a compass
dwolfdwolf Member Posts: 157 ✭✭
 Is there anyway to replace the fluid in a compass?while my boat was being worked on the compass apparently was damaged and all the liquid has leaked out.  It's a dash mounted compass on my  Captiva 232 or is the compass ruined
    You can buy compass oil..not sure how to fill it though
    2002 - 270FV Mag 350 B3
    If the fluid leaked out from damage, it is likely not fixable, unless it's something small like a seal on a fill screw or something. But if the glass was hit hard enough to drain all the fluid, I'd start shopping for a new one.
  • cettialpha6cettialpha6 Member Posts: 42 ✭✭
    edited March 2018
    If this compass has a diode lamp for lumination, I would not risk trying to fix it. A new one is +/- $125. The compass is wired in series with the starting circuit and can be a heII to troubleshoot if it shorts out. I've never had a use for ours because of gps, cell phones and vhf radio. My compass has become an ornament on the dash.
    Mine suffered the same fate- it's the expensive one, I looked at replacing it and it was like a grand so it just sits there on the dash...low priority but I really do want to have one if I get back to the gulf. Realistically, I am never in a body of water that I can't see the shore somewhere.
    I believe you can use mineral, available from any drug store.
    My compass leaked and wasn't accurate. Bought a cheap replacement as filler and bought a Lowrance with GPS with Navionics map. Money better spent.
  • bry1429bry1429 Member Posts: 371 ✭✭✭
    edited March 2018
    My compass lost all liquid last summer. Its not worth spending time or money  filling an old leaky compass .
    Purchase a new one.
    I read an article that said not to use mineral oil....I'll try and find it
    Got a new Richie for under 100 dollars. It was a little smaller but fit the hole and is lighted.
    Likely no way to refill. Been there.
    FYI: if you use your phone compass to try and true your boat compass: make sure the phone is NOT using the cell towers (check your phone settings). It can be WAY off or erratic.  Been there too. lol
