Using MaryKate On & Off
06Rinker27006Rinker270 Member Posts: 1,277 ✭✭✭
This weekend I’ll be waxing my hull.  A few questions:
Before the season wax, is a acid based cleaner necessary?
Looking to use On & off cleaner or their gel.  Option C would be a 50/50 mixture of muriatc acid.  If used, do I need to mask off the bottom painted hull?  Any experience using this would be appreciated.
Patrick
06 Rinker 270
    Is your bottom dirty? I’ve only ever used on/off after leaving my boat in the water for a month with no bottom paint.
    Are you just cleaning the waterline above the bottom paint?  I have had good luck with Starbrite hull cleaner in the spray bottle.  It is also a gel based cleaner. I think it is easier to keep the cleaner in the area you want.  I also use this to clean the waterline in the water.
    https://www.walmart.com/ip/Star-Brite-Hull-Cleaner-Gel-Spray-22-oz/51201194
  • RustySRustyS Member Posts: 83 ✭✭
    If your bottom paint covers your water line I don't feel you need to use the aggressiveness of On & Off. Besides; your bottom paint will not take kindly to it! I haven't seen any non-ablative bottom paint NOT be affected from being touched by acid.
    A cleaner/wax combination should remove any residue/stains in my opinion negating the need for the mess On & Off will create.
    Good Luck!
  • Dream_InnDream_Inn Member, Moderator Posts: 7,869 mod
    For your hull sides, it should not be needed. There are some great cleaners out there for those stubborn stains before waxing.  On/off is for the bottoms that aren't painted.  I used to use it on my 310 that I had lift kept without bottom paint.  Would clean the bottom a few times a year (then I started using muratic/water mix).
    Thanks everyone!
    My goals are to remove anything from the hull sides before I wax and to clean the white water line that is mucked up.
    Patrick
    06 Rinker 270
    @JonnyM you use the starbrite above bottom paint and it doesn’t harm the paint correct?
    Patrick
    06 Rinker 270
    That is correct, I scrub and hose it off quickly and try to keep as much off the bottom paint as possible.
    Thank you sir.  Just picked some up.
    Patrick
    06 Rinker 270
