risers on a closed cooling system
rasburyrasbury Member Posts: 8,891 ✭✭✭✭✭
So, in my journey of pulling the motor to investigate a leak, I learned that my motor is not a 1/2 closed cooling, it is 100% closed cooling which is what I thought I had purchased and sought when I went looking. Somehow, someone convinced me I did not. Anyway- so the raw water only cools the heat exchanger and then a hose goes over to the riser and then out the boat correct? So I pulled them off to get the exhaust elbows apart removing the motor and under the boot is heavily corroded. Obviously was concerned - but thinking it through, does it really matter? Raw water is not going anywhere except out with exhaust- do I really need to replace them?
