Replace 3-pin connector for bilge pump
LaRea
Member, Moderator Posts: 7,999 mod
Anybody know a source for replacing this 3-pin power connector for a bilge pump? Or the brand name of the connector so I can search for one?
The float switch stopped working, and I found that one of the pins in this connector broke off. If I can find one that matches the existing connector, it will save me from having to install a new connector in a tight, hard-to-reach space.
http://www.newark.com/te-connectivity-amp/1-480701-2/plug-socket-housing-receptacle/dp/25C7563?st=MATE N LOCK
http://www.newark.com/te-connectivity-amp/282087-1/connector-housing-receptacle-3/dp/20C2611?st=superseal
I'm not recommending it, just saying it's available. Obviously you would have to change both plug and socket.
