Bridle for Anchor Chain
Willhound
Member Posts: 4,242 ✭✭✭✭✭
I'll be installing a new anchor chain and rode this season, it has 50 feet of 1/4" chain and 150 feet of rope. For a rope bridle I've always used a Prusik knot on a line. The 50' of chain on the new rode is plenty long enough for a lot of our anchor spots, 4 to 6 feet deep, even with a good scope so want to build a chain bridle with a clevis hook. I was able to find one as below, but in 5/16".
Questions: will the 1/6" make a difference? I'm thinking no, the chain will be locked in anyway.
Is the lock tab a nuisance in case I ever need to get the bridle off quickly, or I'm seeing it as a positive feature to keep the chain from dropping out of a regular open clevis?
Stodge, I'm assuming for something like this. I would think the extra 1/16" would not matter.
And a good rule of thumb is a scope of 7 to 1 for good anchor set. So 7 feet of water is 49 feet of chain. If its just a short stop of course I won't bother. But for an overnight I would .
The rode I bought just happened to be rigged with 50 feet of chain. The line should last me forever as it may hardly ever see the windlass.
7' of water depth + 4' above the water surface = 11' of total height above seabed.
7:1 scope requires 77' of anchor rode.
In 7' of water, 49' of chain will hold fine in most situations. But if you have other boats tied to you, and you are expecting weather, you'll want to put out at least 80'.
Is the bridle idea using that hook a good one? The hook, I mean. I already recognize the need and use a bridle.
Actually @LaRea , your calculations are correct if attached to your windlass. If it is attached using a bridle, it lowers that attached point closer to the water and gives a reduced angle (better pull) on your anchor. The picture I attached doesn't really show it, but the further back you attach the two points, the lower that attached point to your rode can be. On mine, it attaches right above the water line (within inches), so technically, I only have to use the depth for my 7:1 (but I always put more out than needed).
Oh, and Willhound, I think your idea is good.
