2005 342 - A/C not pumping water
My Dometic A/C is not pumping water properly. Thoughts? I was thinking maybe the water intake strainer may be clogged up. Where is the strainer located? Thanks
  • browncbr1browncbr1 Member Posts: 55 ✭✭
    The pump may be programmed to cycle. That was the default setting on mine Atleast. Check the operation manual about this before freaking out.
    Pump and strainer and valve are under the port cushion in the aft bunk. Make sure the valve is open. Clean the strainer, with the valve open, bleed out the air from the strainer by unscrewing it a bit. Then restart the a/c.
  • JMGINWV342JMGINWV342 Member Posts: 24 ✭✭
    Black_Diamond,
    Many thanks.  Found the strainer, it was stopped up, cleaned it out, everything working fine now.
    JMGINWV342
