RPM Issues
First opportunity actually get the boat out and run yesterday. Five people, nearly full tank and plenty of beer. Had some storms come up so I decided to run south to get away and when I powered up I noticed the port engine was producing more RPM's than the starboard. Did the tach tap, several times at different levels and nothing. Even at 7-8 MPH it was two hundred higher. Second thing was the port engine seemed to be louder than the starboard. Ideas on where to start?
Not necessarily true. At low speeds, the filter can pass enough fuel. At higher sppeds, the filter can't flow enough.
Mark
2019 MTX20 Extreme
Seriously??!? What engines do you have. Chances are they will be located on the starboard side of the engines down low near the front engine mount. But then again, I'm not familiar with cruisers per se.
Mark
2019 MTX20 Extreme
Have a look here......
Mark
2019 MTX20 Extreme
You may also have separate in-line filters (see attached). Someone here with an '02 342 and 350 Mags will probably have better advice.
Mark
2019 MTX20 Extreme
Trich....
I might be wrong, but I think the sync gauge is measering the thrust from each engine, not RPM. I got into some weeds about month age and used the sync gauge to determine which drive had the weeds on it. Did a bunch of carzy things and got rid of the weeds. When the drives are not in sync with nothing on the props you can hear the difference in the engines when they are in sync. This is how captains used to do it before electronic gauges. When I have the drives in sync my tac's never read the same (cheap guages).
So I think you might have a problem with the props or it might be an engine problem or in rinker 312 problem it might be cables.
Len
Len & Robyn 342 FV Freebird
