Engine hatch won’t open using the two override studs
ALBRIKBALBRIKB Member Posts: 13 ✭✭
my marina tried to open the hatch using the override studs and blew a fuse.  Now hatch won’t open at all, have to manually lift. Trying to figure out why. Checked fuses and reset have some circuit breakers and still nothing.  Trying to locate battery fuse to see if that is why it’s not working... any suggestions
    edited April 2018
    Check for corrosion in the the connector at the bottom of the actuator.  Try unplugging and replugging it a few times.
  • ALBRIKBALBRIKB Member Posts: 13 ✭✭
    We tried several times, we also used jumper cables directly to the actuator and that worked, but won’t open when trying to use the main hatch lift or the bypass used when winterizing
    We feel that when our marina was trying to open the hatch and it didn’t work he tried to jump it off the and blew out something because the fuse was popped when we arrived
    Did you reverse polarity when you tried with the jumpers???
    Checked breaker/fuse?
    Yes.  Tried both but still can’t electrically operate...the breaker on the helm but  don’t know where fuse is or if there
     even is one
  • gausagausa Member Posts: 30 ✭✭
    thanks for this post, happy to report that my Hatch is finally Working perfectly after soon LONG.. thanks everyone
    That's great!  How did you fix it?
  • aero3113aero3113 Member Posts: 9,876 ✭✭✭✭✭
    Good news!
    Albrikb,  Should be just a breaker at the helm, marked "hatch."  I am not aware of any fuse anywhere.  Mine does require a strong battery in order to work.  Sometimes it hasn't worked if the batteries were low unless the engine is running, getting the power from the alternator.  Those little circuit breakers can go bad, and not reset.  That is rare.
    Anyone have a part number for a engine hatch actuator on a 2004 312 rinker fiesta vee.   Ours died
    @ALBRIKB I think I seen someone post on fackbook rinker page this week for $125
    Can’t find it anywhere...anyone have a part number or suggestion where to find new onw
  • rasburyrasbury Member Posts: 8,972 ✭✭✭✭✭
    I bet they are pretty generic...just Google it and see what you get.
    When I was gonna replace mine it basically came down to making sure the extension length and strength were a match. Mine is an acculift but I think they are not around or hard to find so you can swap it with pretty much anything.
    I'd try to get a look at the existing actuator for a make and model, then google that.  Should be able to find specs not to mention replacements.
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Hi, Lenco model # 20782-001,it measures 37" closed and 61" extended. The original Aculift measures 37.5 closed and 55.5 extended . This should fit, would require you to mount both end bases
