Engine struggles
bazza
Posts: 56 ✭✭
280 300hp vp 2010
engine sweet at low speed when trying to get on plane fades back to low revs for a short time changed plugs distributor cap and rotor with new leads and new fuel filter.
I have found the exhaust blocked at the prop but ok above so I think this is the problem boat in water most of the time so animal groth any tips for clearing whilst still in water?
any suggestions gratefully accepted.
thanks Bazza
thanks Bazza
get a coat hanger and make a hook on the end, and have at it.
the boot, aka the accordion exhaust bellow, ought to be swapped out for a 'tube' instead... the premise is the exhaust is routed through the prop at idle and below plane, but up on step (plane)? She breathes, and sounds good too.
exhaust bellows/boots should be done drive off and on the hard.
bazza
thanks Bazza
there is a term that's tossed around that isn't accurate- back pressure. some will say that some 'some' back pressure is good, but that isn't true. 'scavenging' is good, and it is related to exhaust restriction too, but it isn't back pressure. scavenging is the conveying of exhaust pulses down the path, one drawing the other behind it by convection of heat... a bend of proper angle/diameter heats up as hot as the exhaust pulse itself and pulls the pulse toward it... that is good so long as the path beyond it is less restrictive than the pipe in front (or another hot spot introduced further down the path), otherwise you get a 'wall' of denser (cooler) air the next pulse has to push through- creating back pressure.
low in RPM range 'back pressure' SEEMS to assist in building RPM's faster- as the exhaust stroke doesn't purge the cylinder completely due to resisting pressure. the engine sucks in fresh air in the intake valve and it encounters the spent air that reenters the cylinder before the exhaust valve closes, and it makes like thunder as the cooler intake air is rapidly warmed- expanding but not to the point of detonation- it presses the piston downward in an 'assist' that allows greater RPM's to be achieved faster. that 'air', though, is already depleted of o2, so the 'burn' isn't near as stout as it should/could be, and it doesn't need near the fuel as the injection is providing... so... you're losing performance and wasting fuel.
properly designed- less restrictive intake and exhaust- an engine 'seemingly' revs with more effort- extending the rate/timing of building RPM's- but each of those strokes matters more as they're generating more power.
builders 'play' with this concept to get what they want from an engine. an engine with a camshaft profile intended for low end and mid range power curve isn't impacted as much as a profile intended for high end performance- it builds the power and has the power to move the prior exhaust pulse out of the way- the high end engine will labor more to get to the high end than the low end profile as it isn't designed to touch into the power range until later.
Marine engines touch into the power band early and provide it up until the valve trains design of 5500 max, starting to fall off after 5k rpm... fortunately the exhaust path on these engines is short, and there is some argument that washing through the prop at speed actually creates a vacuum for the pulses to escape far beyond what is possible otherwise...
your exhaust being even partially blocked is costing you power...
I will pull the boat out in the next week or two look at it myself or maybe a marine mechanic.
I will post the results
thank you Bazza
This could help to see if there is obstruction.
Thanks Bazza
Yes, has happened to me. Do an internet search and you will see other posts about it.
Many thanks
Bazza
Advise most gratefully accepted.
Thanks Bazza.
