Trim tabs not working
sk520sk520 Member Posts: 8 ✭✭
Good morning fellow boaters. I have a 2003 250 Fiesta Vee. The outdrive raises and lowers but the trim tabs dont. Is there a  motor that operates the trim tabs seperate from the outdrive pump. Any help would be appreciated.
  • LaReaLaRea Member, Moderator Posts: 7,999 mod
    They are probably Lenco electric trim tabs.  Can you get to the back of the trim tab button pad?  Check for loose or damaged cables?
  • sk520sk520 Member Posts: 8 ✭✭
    I can. Ok perfect. Thank you for a starting point. I agree, now that i follow wires etc, they must be electric. Would there be a fuse somewhere "hidden"?
    There's probably a pop-out circuit breaker at the helm.
    There's also a controller box inside the helm.  It's a black plastic box about 3"x4"x1".  Might be zip-tied to the steering rack.  Everything plugs into the controller box (button panel, 12-volt power, and two actuator cables).
